Bounding Box
Bounding Box
Bounding Box
I'm sure that this is a redundant subject but I really need help. By using the bounding box, I would like to determine the length, width, and height of a part. I found this code::: But I'm having a difficult time to set this code in place. Can anyone help me with this? Is there an easier alternative?
Hiram
Public Sub ShowRange()
' Get the active document. This assumes it is a part document.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oBox As Box
Set oBox = oPartDoc.ComponentDefinition.SurfaceBodies.Item(1).RangeBox
Dim strResult As String
strResult = "Part Range Size:" & vbCrLf
strResult = strResult & " X Size: " & Format(oBox.MaxPoint.X -
oBox.MinPoint.X, "0.000000") & " cm" & vbCrLf
strResult = strResult & " Y Size: " & Format(oBox.MaxPoint.Y -
oBox.MinPoint.Y, "0.000000") & " cm" & vbCrLf
strResult = strResult & " Z Size: " & Format(oBox.MaxPoint.Z -
oBox.MinPoint.Z, "0.000000") & " cm"
MsgBox strResult
End Sub
> easier alternative?
The code works fine... what's the problem?
I get an error message regarding the syntax at Public Sub ShowRange(). I think I'm probably doing something wrong. Should I try to copy and paste in the VB Editor? What steps are you taking?
Where are you pasting this code now to give an error message at Public Sub
ShowRange()?
Tools>macros>visual basic editor. I started a new project and I pasted the code in module 1. I made a mistake by saying that it was in Public Sub Showrange (). It was actually in
The above was highlighted red due to statement overlapping. I fix that problem now the code runs until Set oPartDoc = ThisApplication.ActiveDocument
The error that I get is run-time error 13 type mismatch
> ThisApplication.ActiveDocument The error that I get is run-time error 13
> type mismatch
Then your active document in Inventor is not a part...
What about getting sizes of assies bounding box? Any ideas?
