Issue with FlatBendResults Object
Raider_71
Message 1 of 8
Raider_71
Hi everyone,
I have come across an issue with the FlatBendResults object in a specific case. In general, the results are good but when used with a bend that was "split" with let's say a cut in the folded model, then the results seem to be incorrect.
I cant seem to be able to get the Start and End points/vertices of some of the bend lines.
To keep the explanation simple I have attached a part file for reference.
The code below will insert a Work Point at each endpoint of the bend lines. If you run this you will see what I mean. Is this a known bug or am I missing something here?
Open the part and activate the Flat Pattern. Then run the code. Check the points created in the Flat Pattern environment.
    Private Sub BtnAddWorkPoints_Click(sender As Object, e As EventArgs) Handles BtnAddWorkPoints.Click
        Try
            oApp = Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
            MessageBox.Show("Could not connect to Inventor.")
            Exit Sub
        End Try
        Dim oTransGeom As TransientGeometry
        oTransGeom = oApp.TransientGeometry
        Dim oPartDoc As PartDocument = oApp.ActiveDocument
        Dim oSmCompdef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
        Dim oFlat As FlatPattern = oSmCompdef.FlatPattern
        Dim oTopFace As Face = oFlat.TopFace
        If oFlat.FlatBendResults.Count > 0 Then
            For i As Integer = 1 To oFlat.FlatBendResults.Count
                oFlat.WorkPoints.AddFixed(oFlat.FlatBendResults.Item(i).Edge.StartVertex.Point)
                oFlat.WorkPoints.AddFixed(oFlat.FlatBendResults.Item(i).Edge.StopVertex.Point)
            Next i
    End Sub
Any help would be appreciated!
Cheers
Replies (7)
Message 2 of 8
YuhanZhang
This is reproducible issue and I logged it as INVGEN-67251.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 3 of 8
Raider_71
Thank you!
Message 4 of 8
YuhanZhang
@Raider_71 I just remembered that we made a fix for this issue in Inventor 2021 already, your data was created with an older Inventor so you can see that problem, if you now upgrade to Inventor 2021 or later versions, you can see the fix. Please note that for the legacy data you should delete the Flat Pattern and re-generate it in newer Inventor, only migrate the legacy data could not make the issue disappear.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 5 of 8
Raider_71
I will check on this but I am sure that I created a new part using Inventor 2023. Let me check and get back to you ok.
Message 6 of 8
Raider_71
Hi, ok I see what you mean. I think I may have created or used an old file and even opening it in 2023, it still provided the incorrect result.
Now if I delete and recreate the flat pattern then it works as it should.
Also creating a new file in 2023, it works!
Thanks for your help!
Message 7 of 8
JMGunnar
Is there Notch in Bendlines EndPoint?
@Raider_71
Johan
Message 8 of 8
Raider_71
Hi @JMGunnar
There are no notches in the sample part no. We have developed an application to insert either Circular or V-Notches. The issue was that we could not get the correct endpoints of the bend lines if the file or flat pattern was created with Inventor 2020 or before.
But this seems to be solved since Inventor 2021 and our app is working just fine now.
