Can Anyone explain how to use this snippet - oLast3Chars = Left(Right(oRefDoc.FullFileName, 7), 3)
J.VandeMerckt
J.VandeMerckt
 I understand it uses the last 3 characters of the original name.
I would want to use the whole name but don't understand this Left and Right fully.
Can anyone elaborate for me?
Thank you.
Daan_M
What do you mean exactly?
Is what you need if you want the entire file name
'Left' and 'Right' functions just cut out a part of a string
lets say I have 'abc'  and i use function:
Right('abc',2), the result will be: 'bc'
Left('abc',1), the result will be: 'a'
If you combine these function within eachother brackets, it will cut out a part of the already cut out part, so basically when i use the function i stated above:
I can adjust this to Left(Right('abc',2),1), the result will be: 'b'
Because the result of my first function was 'bc' and i take the 1 left character from it, which is 'b'
J.VandeMerckt
Ty sir, this is exactly the explanation I was hoping for.
I will try oRefDoc.FullFileName too.
