Issue with debugging Inventor 2013 addin with VB.net 2010
MattH_Work
Advisor Advisor
MattH_Work
Is I build my addin useing .Net Framework 2 I can run Inventor, run my addin and everything works as expected (with the expected performance) but I CAN NOT debug my app, if I buld it with Net Framework 4 debugging is available but Inventors performance drops throught the floor (files which should take seconds to open suddenly take minutes)
Is there a definetive way of setting up my addin AND / OR Inventor to give me debugging and normal performance at the same time?
Regards
MattH
MattH
Product Design Collection 2027
Vault Pro 2027
xiaodong_liang
Autodesk Support
Autodesk Support
It is true you need framework 4.0 to debug inventor application because 2013 product uses 4.0. The other thread also mentions this
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Cannot-debug-2013-with-VS2010-VB-NET/t...
As to performance, I heard this may be due to 4.0 requires loading more  functions than before.
nmunro
Matt,
See this topic for information on slowness with Visual studio 2010 and Inventor 2013.
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/VS-2010-and-Inventor-2013/m-p/3601532#...
https://c3mcad.com
