Issue adding end treatments to authored structural members
G60Dub
G60Dub
Hi everyone
I have a strange one here and not quite sure what is amiss.    I have authored some structural ally extrusions for use in Frame Generator which seemed to be all well and fine.
The frame members appear as they should when dropped onto the skeleton sketch but I am unable to perform the majority of end treatments on them and the following attached message is displayed:
'We can't use the frame member in the selection'
I've authored plenty steel frame members in the past so not sure whats going on - The double lip seal in the same OTHER folder functions as expected with end treatments.
Jon.Dean
Hi @G60Dub,
Would it be possible to share one of your Authored parts with us, so I can take a look?
Cheers
Jon.
Jon Dean
G60Dub
Hi Jon
Do you want a template or a part generated from the content center?
Jon.Dean
Hi @G60Dub,
If you place one of the authored parts into an assembly, select custom before placing and save it to your workspace, then send it to me.
Cheers
Jon.
Jon Dean
