Is tube and pipe good for route which have customized bends and fittings?
HermJan.Otterman
to create Pipe routes this is the best way, but you can only use 90 and 45 degree angles and they have to be in the content center
with tubes you can bend it in any angle. once you get to know how to use it, it work good!
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
liminma8458
Hi, Herm,
What does it mean "with tubes(pipes) you can bend it in any angle"? how do you do that? how to put this angle-adaptive pipe angle in the "Tube and Pipe Styles". Sometimes, we do have some bending pipe structure such bending it in 100 degree or 150 degree.
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
