Is there a way to save a component definition?
JBEDsol
JBEDsol
I have a code that uses assembly component definitions a lot.  When I try to save as I get errors.  If I'm starting w/ a component def how do I get the documents so that I can save the file?
JBEDsol
I tried saving the document with this line.
asmDoc.SaveAs(strFileName, False)
I get an error stating
Failed to create folder,""
I've no idea what's going on.
I got the same thing with the line
asmDef.Parent.SaveAs(strFileName, False)
snappyjazz
Hello@JBEDsol
If I understand what you're after, the document is part of the component definition. You'll want to convert that to an assembly document. From that assembly document you can save.
Dim SavDoc as Inventor.AssemblyDocument = AsmCompDef.Document
SavDoc.Saveas("FileName",False)
dgreatice
where did you get Assembly Component Definition? Drawing?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
