add parts list in the lower corner using API
Hello all,
I am trying to add a parts list into a drawing using the API. Adding the list itself is not the problem, however the placement is rather tricky.
The drawing informtion is placed in the lower left corner. I want to place a parts list on top of the infobox.
The amount of parts varies because the assembly it corresponds to is configurable.  So when there are less parts a gap appears between the drawing info and the parts list. (see image for example)drawing example.png
Also, here is the code I got from the inventor API/programming help page.
On Error Resume Next
    ' Set a reference to the first drawing view on
    ' the sheet. This assumes the first drawing
    ' view on the sheet is not a draft view.
    Dim oDrawingView As DrawingView
    oDrawingView = oSheet.DrawingViews(1)
    ' Set a reference to th sheet's border
    Dim oBorder As Border
    oBorder = oSheet.Border
    Dim oPlacementPoint As Point2d
        ' There is no border. The placement point
        ' is the top-right corner of the sheet.
       oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(41, 12.5)
    ' Create the parts list.
    Dim oPartsList As PartsList
    oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
How can ik make the partslist snap to the drawing info box regardless of the amount of parts?
Thank you in advance.
Lennart
JhoelForshav
How about something like this? 🙂
Dim oSheet As Sheet = ActiveSheet.Sheet
xrev = oSheet.TitleBlock.RangeBox.MaxPoint.X
yrev = oSheet.TitleBlock.RangeBox.MaxPoint.Y
oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(xrev, yrev)
oPartsList.Position = ThisApplication.TransientGeometry.CreatePoint2d(xrev, yrev + oPartsList.RangeBox.MaxPoint.Y - oPartsList.RangeBox.MinPoint.Y)
Thank you @JhoelForshav,
your code worked great.
At line 6 I have added + 1.5 because the list overlapped the titleblock a bit.
It looks great now! 😃
