Is there a way to do this in iLogic? (Create a set of rotated planes)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Here's what I am trying to do, I'd like to create a set of rotated planes, that can be user defined for the number of planes, I will consider "Y" to be the "UP" direction and the XY plane will be considered "0 deg", all other planes will rotate based off the XY plane, and each plane will rotate the same angle from all other planes.
I'm trying to follow along with the attached tutorial:
Example:
I want 35 planes, each rotated at 10 from 0, or I could decide I want 72 planes, each would be rotated 5 deg from 0, I can't think of an easy way to auto create planes if I decide I want more, without creating 360 planes and turning off the one I don't need.
However, once a plane is created, If I then choose a smaller number of planes I don't want to delete any of the previously created planes, as they may have sketches on them, I'd rather just turn those off along with their sketches, if possible?
I assume there is a way to do this, I just can think of how to do it, I could use some help
