Is their anything wrong with code?
mslosar
Advisor Advisor
mslosar
It's based of another post and modified. Essentially i'm having to set the visibility, etc of all the pieces of a circular pattern.
The rule works completely fine in the assembly it's written in. This assembly inserted into another assembly. When saving all files in the upper level assembly, it generates and error on this rule in the sub assembly.
The code:
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oPattern As OccurrencePattern
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("FRS_Pattern 3:1")
Dim oPatternElement As OccurrencePatternElement
For Each oPatternElement In oPattern.OccurrencePatternElements
	Dim oOcc As ComponentOccurrence
		For Each oOcc In oPatternElement.Occurrences
			If FRS_SEGMENTS= 1 then
				oOcc.Enabled = False
				oOcc.Visible = False
				oOcc.BOMStructure = 51972
				else
				oOcc.Enabled = True
				oOcc.Visible = True
				oOcc.BOMStructure = 51969
			End if
		Next
	Next
The error:
iLogic Rule Error in rule: FRS_YN, in document: U_TIP_BODY_ASSY.iam
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.OccurrencePatterns.get_Item(Object Index)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at e.a(String A_0)
just thinking out loud..if you set  oDoc = ThisApplication.ActiveDocument your setting the oDoc = to the upper and not = to the assembly the code is writen in?
mslosar
I think that's right.
I changed it to ThisDoc.Document and it's passed the few tests i've thrown at it thus far.
Fingers crossed that it lasts. 🙂
After posting i went back and stared at it and was thinking the same thing.
