Is that Possible to fix the drawing even though the model parameter has changed.
I have a drawing which i want to define the dimension in equations. Hence, i don't wish the drawing to be changed when there is a change in model parameter.
Is possible to fix the drawing only because i still need to change the title blocks information.
YuhanZhang
Did you try the Defer Updates if it works for your case? You can set this when you open a drawing document in the Options, or after opening it you can set it in the Tools->Document Settings->Drawing.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
