- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am creating a configurator which builds assemblies from the ground up. So far so good. I just wanted to check if anyone had found a way to constrain a subassembly rather than a part using the new constraints.add... commands in ilogic. It would make my life a lot easier. The 'named geometry tab' is not accessible in an assembly file so my guess is it is not possible- unless someone knows a workaround.
Roger Mitchell
IV2020.2.1
