Is it possible to search in drawing for Revision number?
GKR2023
GKR2023
I am using this code
'define the active document as an assembly file
Dim oInvApp As Inventor.Application = ThisApplication
'make sure that the active document is an assembly file
If oInvApp.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the build file.", "iLogic")
	Exit Sub
Dim oAsmDoc As AssemblyDocument = oInvApp.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
oRevNum = iProperties.Value("Project", "Revision Number")
Dim oProjectNumber As String = Mid(oFilePath, 56, 6)
oPath = "C:\Exports\01 - DXF Exports" & oProjectNumber & "\"
'Getting User input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all the components of the assembly made of sheet metal." _
& vbLf & "This rule assumes that the part file will be saved." _
& vbLf & "Only sheet metal parts for which the specification structure is set to the normal value will be exported" _
& vbLf & " " _
& vbLf & "Are you sure you want to create a DXF for all the components of a sheet metal assembly?" _
& vbLf & " " _
& vbLf & "This may take some time.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
'process the drawing files for the referenced models
'at the same time, it is expected that the model has been saved
For Each oRefDoc As Document In oRefDocs
	'check if the document is a sheet metal part
	If oRefDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
	'check if the normal structure of the specification is set
	If oRefDoc.ComponentDefinition.BOMStructure <> BOMStructureEnum.kNormalBOMStructure Then Continue For
	'make sure that the model is saved
	If Not System.IO.File.Exists(oRefDoc.FullFileName) Then Continue For
	Dim oPDoc As PartDocument = oInvApp.Documents.Open(oRefDoc.FullFileName, True)
	Dim oSheetDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
	Dim ThicknessSM As Inventor.Parameter = oSheetDef.Thickness
	Dim Thickness As String=ThicknessSM.Value * 10
	oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName)- 4)
	On Error Resume Next
	oStyle = oSheetDef.ActiveSheetMetalStyle.Name
	Dim oTO As TransientObjects = oInvApp.TransientObjects
	oDataMedium = oTO.CreateDataMedium
	oContext = oTO.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = oTO.CreateNameValueMap
			Dim oPropSet As PropertySet = oInvApp.PropertySets.Item("Inventor Summary Information")
			Dim oProp As Inventor.Property = oPropSet.Item("Revision Number")
			oRevNum = oProp.Value
			If oRevNum = "-" Then oRevNum = ""
			If oRevNum = "" Then
				oRevtxt = ""
			Else
				oRevtxt = " - REV"
	'get the path to the target folder DXF
	oFolder = oPath & "\" & oAsmName & "\" & oStyle & "\" & Thickness
	If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder)
	oDataMedium.FileName = oFolder & "\" & oFileName & " - " & oRevtxt & oRevNum & ".dxf"
	'  & oPDoc.ActiveMaterial.DisplayName &  VOOR ALS JE MATERIAAL WILT TOEVOEGEN AAN DE BENAMING
	If oSheetDef.HasFlatPattern = False Then
		oSheetDef.Unfold
	Else
		oSheetDef.FlatPattern.Edit
	Dim sOut As String
	'sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR?OFILE"
	'sOut = "FLAT PATTERN DXF?AcadVersion=2004&RebaseGeometry=True&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerColor=255;0;0&BendUpLayerColor=255;0;0&BendDownLayerLineType=37641&BendUpLayerLineType=37639IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES"
	sOut = "FLAT PATTERN DXF?AcadVersion=2018&MergeOuterContour=True&MergeProfilesIntoPolyline=True&RebaseGeometry=True&Feature" _
	           + "&FeatureProfilesLayer=IV_FEATURE_PROFILES&FeatureProfilesLayerColor=0;255;255&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN&FeatureProfilesDownLayerColor=0;255;255" _
			   + "&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL"
	oSheetDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
	oSheetDef.FlatPattern.ExitEdit
	oPDoc.Close()
Next
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new ffiles are saved
Shell("explorer.exe " & oPath,vbNormalFocus)
And I was wondering if it is possible, that it searches for the revision number in the drawing instead of the part it self?
Ciao
A.Acheson
Hi @GKR2023
You won't be able to search the reference files directly because the reference document(child) doesn't know anything about it's (parent) the drawing.
If you keep the drawing in the same folder or a known folder of given path then you can create a fullfilename for the drawing and try to open it and then retrieve the revision number.
So something like this workflow.
C:temp\Part.ipt
Replace .ipt with .idw
Check it exist(C:temp\Part.idw)
Open Drawing
Get Revision Number
Regards
Alan
