Is it me or c sharp? I'm leaning towards me... AddUsingSheetFormat -->2026
Tiffany_Hayden_
Tiffany_Hayden_
I'm having an issue not "having" to give the model doc in AddUsingSheeetFormat in 2026.
If I don't give it the modeldoc it will give me an error parameter incorrect.
               object missing = Type.Missing;
               string activeDocPath = ActiveDrawing.ReferencedDocuments[1].FullFileName;
               Document modelDoc = (Document)invApp.Documents.Open(activeDocPath, false) ;
               Sheet newSheet = drawingSheets.AddUsingSheetFormat(sheetFormat, modelDoc, "", null, null, null);
But if I use the model doc it adds a view to the sheet and a Parts list automatically. Is this new functionality? Or am I just using the API wrong.
I'd like to do this.
                Sheet newSheet = drawingSheets.AddUsingSheetFormat(sheetFormat, null, "", null, null, null);
Before you ask. 🙂 I have validated that my sheetformat exists and is pointing to the correct one. There are no prompts when adding a sheet manually.
Thanks for any help!
Tiffany
Tiffany Hayden
hollypapp65
Try:
Sheet newSheet = drawingSheets.AddUsingSheetFormat(sheetFormat)
Tiffany_Hayden_
I've tried that too. I read that but I'm not sure how you go about not using the model doc as the second input. Is there a workaround?
Tiffany Hayden
Tiffany_Hayden_
It looks as though this pops up when you create a sheet from the sheet format; the model doc is required. The API documentation doesn't make this clear. But that's how it goes sometimes.
The fix is to create a sheet format off of a blank sheet created from the original format, doing that will no longer require the model document as input.
Steps:
Create new sheet from drawing right click create sheet.
Right click on new sheet
Create Sheet format
Rename new Sheet format
Save
In code use new sheet format.
Tiffany Hayden
