Is Error is fighting with On Error
JBEDsol
JBEDsol
I have a code w/ some error checking.  On Error goto......  The problem is when I'm trying to find something missing I get an error. I want to do an if then checking if something exists. if it's an error then I know it doesn't exist.  If it's not an error I can get the value.  Problem is if there's an error it goes to the error checking area.  I just want to check if there's an error rather than go to the error checking.
Rene_Gerlach
Maybe you can try:
on error resume next
if err.number <> 0 then somthing went wrong
JBEDsol
The issue is I'm trying to find if there's an error or not for one specific situation.  If I use resume next then I skip the error checking.  I want error checking for other errors.  But in one specific case I just want to see if it's an error or not without actually causing the error.
Rene_Gerlach
Hope I understand you right.
You can call
On Error Resume next
before the call you are interested in. Then check the Err.Number and after this reset to the default error handling with On Error Goto 0
or with
On Error Goto <line>
If this is not what you need could you explain the "specific case"?
JBEDsol
Thanks, I'll try that and see if it works out.
