- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have written code to allow me to pick the dimensions of a part and update the dimension parameter name from a list of choices presented in a form e.g. length, width, thickness, outer_diameter, wall etc.
The parameters are exported and I can get overall sizes in the BOM with relevant expressions in columns. So far so good.
What I would like to do is have a global SIZE column in the BOM which has expressions that vary based on another custom iproperty (PartType) which defines the part. So for example if the PartType was 'circular plate' the expression in that parts row of the SIZE column would be <outer_diameter>x<Thickness> while if the PartType was 'tube' the expression in the that parts row would be <Outer Diameter>x<Wall>x<Length> etc
If I could do this I would not need different columns to define the sizes of every different type of material we use and also limit the number of parameters the user needs to choose from when picking part dimensions.
However looking at the BOM API I do not see an obvious way to alter the expressions. If anybody knows any better I would very much appreciate a pointer in the right direction
Roger Mitchell
