IPT iLogic Rule error while in IAM
pedronicolosi
pedronicolosi
Hey everyone!
Recently I added this rule to my ipt sheet template (I found this rule here, at Autodesk Knowledge).
Dim oSMDoc As PartDocument = ThisApplication.ActiveDocument
Dim oSMDef As SheetMetalComponentDefinition = oSMDoc.ComponentDefinition
If oSMDef.HasFlatPattern = False Then
MsgBox("There is no Flat Pattern yet.", vbOKOnly, "NO FLAT PATTERN")
Return
End If
Dim oTopFace As Face = oSMDef.FlatPattern.TopFace
Dim oMeasureTools As MeasureTools = ThisApplication.MeasureTools
Dim oLoopLength As Double = 0
For Each oEdgeLoop As EdgeLoop In oTopFace.EdgeLoops
oLoopLength = oLoopLength + oMeasureTools.GetLoopLength(oEdgeLoop)
Next
iProperties.Value("Custom", "CONTORNOTOTAL") = Round(oLoopLength*10)
Inside the IPT template, this rule is working fine! No problems at all!
But, if I add the IPT with this rule to a IAM enviroment and save it, it gives me this error in rule:
ERROR MESSAGE
Error in rule: CONTORNOTOTAL, in document: Peça6.ipt
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: There is no support to this interface (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
MORE INFO
System.InvalidCastException: Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: There is no support to this interface (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Does anyone knows the cause of it and how to fix it?
Thanks!!
JelteDeJong
The problem is in your first line. in an assembly it will set the oSmdoc to the assembly instead of the part. try it like this:
Dim oSMDoc As PartDocument = ThisDoc.Document
    Return
End If
Next
iProperties.Value("Custom", "CONTORNOTOTAL") = Round(oLoopLength * 10)
Jelte de Jong
Blog: hjalte.nl - github.com
pedronicolosi
thanks for your help, @JelteDeJong !!
it worked pretty well!! 🤜🤛
