iProperty Thumbnail to Image
Message 1 of 9
i have some Problems to find a Solution to Convert  the Thumbnail iProperty Value
  Dim thumbnail As IPictureDisp = thumbProp.Value
   Dim objImage As System.Drawing.Image
                objImage = Microsoft.VisualBasic.Compatibility.VB6.Support.IPictureDispToImage(thumbnail)
and all this without ...Support.IPictureDispToImage then this is !!Obsulet!!
so Wayne Brill  have some Solution on this Side but this is Image ==> iPictureDisp
http://modthemachine.typepad.com/my_weblog/2012/02/bitmaps-without-vb6-icontoipicture.html
or this in Support Blog from Philippe Leefsma
http://adndevblog.typepad.com/manufacturing/2012/06/how-to-convert-iconbitmap-to-ipicturedisp-withou...
and the solution from Microsoft or some other Peoples work rundomized most Time not!
Public Class PictureToImageConverter
    Inherits System.Windows.Forms.AxHost
    Public Sub New()
        MyBase.New("{63109182-966B-4e3c-A8B2-8BC4A88D221C}")
    End Sub
    Public Shared Function Convert(ByVal iPicture As stdole.IPictureDisp) As System.Drawing.Image
        Return CType(System.Windows.Forms.AxHost.GetPictureFromIPicture(iPicture), System.Drawing.Image)
    End Function
End Class
pls Help thx
Mario
Replies (8)
Message 2 of 9
manuel.lanthaler
Hi Mario,
im also using the last approach you posted and its working well for me.
Another possible solution could be to directly extract the Thumbnail from the file using the Windows API Code Pack library.
An example can be found here: http://stackoverflow.com/questions/1439719/c-sharp-get-thumbnail-from-file-via-windows-api
hope it helps
Manuel
coolOrange
www.coolOrange.com
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos.
Message 3 of 9
Balaji_Ram
Hi Mario,
Here is a code snippet that my colleague Philippe Leefsma had recently used for converting the IPictureDisp to a System.Drawing.Image.
It uses the OleSavePictureFile to save a temporary WMF file which is then read into a System.Drawing.Image.
<DllImport("oleaut32.dll", EntryPoint:="OleSavePictureFile", ExactSpelling:=True, PreserveSig:=False, SetLastError:=True)> _
        Public Shared Sub OleSavePictureFile(Picture As stdole.IPictureDisp, <MarshalAs(UnmanagedType.BStr)> filename As String)
        End Sub
Dim oPD As Inventor.IPictureDisp
oPD = thumbProp.Value
'Check that an image was returned.  It's possible for a
                'file to not have a thumbnail.
                If oPD Is Nothing Then
                    MsgBox("The active document doesn't have a thumbnail.")
                    Return
                End If
                Dim fileName As String
                fileName = "D:\Temp\PartThumbnail.wmf"
                OleSavePictureFile(oPD, fileName)
                Dim img As System.Drawing.Image
                img = System.Drawing.Image.FromFile(fileName, True)
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Message 4 of 9
thanx for the Answers
is there another Solution to get a "Thumbnail" from Document to a ImageBox without IPictureDisp from iPropertys?
thx
Mario
Message 5 of 9
Balaji_Ram
Hi Mario,
In this blog post, Brian explains all the other possibilities.
But i think all of them deal with IPictureDisp.
http://modthemachine.typepad.com/my_weblog/2010/06/accessing-thumbnail-images.html
Is there a specific issue that you have with the code that i posted earlier ?
It saves the WMF to a folder and any image format can be created from it.
Balaji
Balaji
Message 6 of 9
Message 7 of 9
Works Perfect thx
Message 8 of 9
Yes, It works fine with great performance. (it takes only 2ms in my PC)
Message 9 of 9
martinhoos
Hello, would you so kind and post the hole code. I like to get the thumbnails as pic.
Thanks in advance
Regards
Martin
