iProperty SDK editor system.OverflowException Unhandled exception
andrew_canfield
andrew_canfield
Trying a program from the SDK & seeing these returned - what do the messages mean & how are they fixed?
Thanks for taking a look. The error occurs when trying to edit an iproperty of an .idw, the file is read/write.
(same result for .ipt .iam)
Regards
Andrew
AlexKorzun
AddrOfPinnedObject() returns IntPtr:
https://docs.microsoft.com/en-us/dotnet/api/system.runtime.interopservices.gchandle.addrofpinnedobje...
IntPtr.ToInt32() is described at:
https://docs.microsoft.com/en-us/dotnet/api/system.intptr.toint32?view=netframework-4.8
The Exceptions section reads:
OverflowException
On a 64-bit platform, the value of this instance is too large or too small to represent as a 32-bit signed integer.
You should probably use .ToInt64() instead, which returns long. This will require other changes in your code.
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
