Iproperty from different model states
RyanRausch
RyanRausch
I am currently using the following code to pull the mass of a part part/assembly into a drawing.  Is there a way to modify this code so it uses the active model state that the drawing is using?
Thank You
Frederick_Law
Mass from drawing view is from the ModelState in the view.
Same for all iProperties.
Don't need special code to get them.
RyanRausch
I am assuming you are talking about when you use a text you can pull the mass and other properties directly from the model.  This doesn't work with they way we want to use the mass view.
