iProperties "Location" using VBA
isocam
isocam
Can anybody help???
How can I get the "Location" iProperty using Inventors VBA?
Please see the attached picture!
I am using the following code to get other iProperties, thus.....
Set oStockNumberProperty = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Stock Number")
StockNumber = Trim(oStockNumberProperty.Value)
This works OK.
Many thanks in advance!!!!
Vladimir.Ananyev
Location of the opened Inventor document can be easily found from its full file name. Here is the VBA sample:
Private Sub GetLocation_2()
  Dim oDoc As Inventor.Document
  Set oDoc = ThisApplication.ActiveDocument
  Dim Filename As String
  Filename = oDoc.FullFileName
  Debug.Print Location(Filename)
End Sub
Function Location(Filename As String) As String
  Location = Left(Filename, InStrRev(Filename, "\") - 1)
End Function
If you need an access to another file-related utility functions you may also consider Inventor.FileManager object functionality.  For example folder name can be found using powerful FileSystemObject that provides access to a computer's file system (see Microsoft VBA help on FileSystemObject methods and properties).
Private Sub GetLocation_1()
  Dim FSO As Object
  Set FSO = ThisApplication.FileManager.FileSystemObject
  Dim FolderName As String
  FolderName = FSO.GetParentFolderName(Filename)
  Debug.Print FolderName
End Sub
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
isocam
Thanks for the reply.
I should of mentioned that the "Location" property I require is part of a BOM export VBA module.
Here is a bigger snippet of code (reduced from its original to post to the forum)
Public Function QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator)
    For Counter = 1 To oBOMRows.Count
        Dim oRow As BOMRow
        Set oRow = oBOMRows.Item(Counter)
        Dim oCompDef As ComponentDefinition
        Set oCompDef = oRow.ComponentDefinitions.Item(1)
PROBLEM LINE!!!!
        Set oLocationProperty = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Location")
        Set oPartNumberProperty = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number")
        Set oDescriptionProperty = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Description")
        Location = Trim(oLocationProperty.Value)
        PartNumber = Trim(oPartNumberProperty.Value)
        Description = UCase$(Trim(oDescriptionProperty.Value))
        Quantity = Val(oRow.ItemQuantity)
        ItemNumber = oRow.ItemNumber
        If Not oRow.ChildRows Is Nothing Then Call QueryBOMRowProperties(oRow.ChildRows)
    Next
End Function
Everything else (Description, Stocknumber etc works fine, its just the "Location" property that is the problem!
Can you help?
Kindest Regards
IsoCAM
Vladimir.Ananyev
There is no iProperty "Location" among Inventor predefined properties.   Try the following VBA sample - it prints names of all existing iPrpperties.
Private Sub PrintAllPropNames()
  Dim oPropSet As PropertySet
  Dim oProp As Inventor.Property
  For Each oPropSet In oDoc.PropertySets
    Debug.Print oPropSet.Name
    For Each oProp In oPropSet
      Debug.Print "    " & oProp.Name
    Next
  Next
  Beep
End Sub
 Nevertheless you are able to get the reference to the Document object from BOMRow and then you can get the current  file locatio. Methodsn were described above.
Cheers,
Vladimir Ananyev
