iProperties - Opening Using VBA
isocam
isocam
Can anybody help?
I am opening, using VBA, the iProperties "Pop Up" box, using the following code....
ThisApplication.CommandManager.ControlDefinitions.Item("AppiPropertiesWrapperCmd").Execute
Can anybody tell me if it is possible to open the iProperties "Pop Up" box at a specific Tab, for example, "Physical" or "Status" etc?
Many thanks in advance!!!!
IsoCAM
xiaodong_liang
Autodesk Support
Autodesk Support
I do not think this is a question with Inventor API. What I can think of is to use SendKeys. e.g.
Sub test1()
Dim oCol As ControlDefinition
Set oCol = ThisApplication.CommandManager.ControlDefinitions.Item("AppiPropertiesWrapperCmd")
SendKeys "^{TAB}", True
oCol.Execute
End Sub
But, it does not work.. I'd suggest consulting with MSDN if there is any solution.
