iPropertie
iPropertie
GosponZ
iPropertie
GosponZ
i have custom iPropertie named partx (ipt level), but i would like value of that propertie to set in Project-Authority on assembly level.
 If i have subassembly which consist 2 -5 parts max. then i have to manualy type value for authority. So i want from subassembly to pull custom value of one part (partx).
Can somebody help please
Thank you
jdkriek
Here's what that looks like in iLogic:
Dim oDoc As Document = ThisDoc.Document
Dim oRefDoc As Document
For Each oRefDoc In oDoc.AllReferencedDocuments
	If oRefDoc.DocumentType = kPartDocumentObject Then
		modelName = IO.Path.GetFileName(oRefDoc.FullFileName)
	Try
		' Set the value
		iProperties.Value("Project", "Authority") = iProperties.Value(modelName, "Custom", "partx")
	Catch
	End Try
Next
iLogicVb.UpdateWhenDone = True
 You could narrow this down if you know the name of the part each time, otherwise it will just go through all the refrenced documents looking for that property.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
GosponZ
I apreciate this is working perfectSmiley Happy
jdkriek
You're welcome 😉
Jonathan D. Kriek
