How to exclude drawing sheet from dwf when check-in.
Hi All,
I am using Inventor 2012 64 bit with Win 7.
We have a lot of drawing that has some extra sheet for ref. and Inventor let me exclude count and print from those extra sheet. This work fine but when we check-in the drawing to vault it update or publish all sheet to dwf. This is very compuss for us because we full the dwf file from vault to release and the sheet count is different than the print out.
Is there a way to EXCLUDE those sheet when check-in or update dwf?
wayne.brill
Hi Steve,
Is this an Inventor or Vault API question? It seems like it could be a user interface issue. If it is related to default user interface behavior the question should be asked in the Vault discussion group.
http://forums.autodesk.com/t5/Autodesk-Vault/bd-p/101
If this is an API issue please provide some code that shows the problem.
Wayne Brill
Developer Technical Services
Autodesk Developer Network
