iParts: Delete feature if suppressed in every row
waynehelley
waynehelley
Hi there,
I started with a huge ipart table which was created by a collegue who has now left.  The factory was unmanageable as it had reached the maximum amount of columns and was running very slowly.
To combat this, I decided to split the table in half so that the ipart will become two iparts.  I am now working on the first half...
A lot of features are unque to one or a few parts, so doing this enabled me to delete columns if all values in the columns matched after the table was halved.
I thought this would speed up the file but I have now realised I have a bunch of features sat in the browser than are suppressed in every member!
Is there any way to use ilogic or vba to run a script that will delete a feature if it is suppressed in every member?
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
adam.nagy
Autodesk Support
Autodesk Support
Hi Wayne,
I hope this helps: http://adndevblog.typepad.com/manufacturing/2013/05/delete-suppressed-features-in-ipart.html
Cheers,
Adam Nagy
Autodesk Platform Services
