- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to change the custom properties of all the renamed parameters in all parameter collections. For this I already found some code snippets that look at the property "Renamed", when it's true, this is a parameter to change its properties of. But when running the code, and having a watch on what parameters are parsing through the code, via the API I found out that in the ReferenceParameters collection are more parameters of which the property "Renamed" is true than the parameter list in the Inventor Part environment shows (see picture below). The extra 9 parameters that are in the collection are all related to sheet metal parts, but my part is no sheet metal part. I've tried to find out how to distinguish the sheet-metal-reference parameters (which are not visible in the parameters list) from the driven parameters that I induced in my part, but no success. Even though the 'visible'-property of all sheet metal parameters is set to "True", they are invisible in the parameters list. Does anyone know how to skip the parameters not visible in the parameters list?
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
