Inventor will not update PDF Rev.Number on save and export
maskintegning_dk
Message 1 of 8
maskintegning_dk
Hello.
Help me please. When I save .idw I have an iLogic rule which exports to PDF.
The problem is that in the browser, it overwrites the already saved PDF and does not update the Rev.Number.
So it keeps saving as Rev.F.
It should have been Rev.G
I have the rule from Inventor 2020, where it works without problems.
I'm using Inventor 2024 now.
I'm not very strong in iLogic. I am attaching iLogic rule.
'------start of iLogic-------
oPath = ThisDoc.Path
oFileName = iProperties.Value("Custom", "sags nr.")
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim iSheetNumber As Integer
'step through each drawing sheet
For Each oSheet In oDrawing.Sheets
'find the seperator in the sheet name:number
lPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(oSheet.Name)
'find the sheet name
sSheetName = Left(oSheet.Name, lPos -1)
'find the sheet number
iSheetNumber = Right(oSheet.Name, sLen -lPos)
'set PDF Options
'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 4800
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = iSheetNumber
oOptions.Value("Custom_End_Sheet") = iSheetNumber
'End If
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
‘Get title From model iProperties
oRefDoc = ThisDrawing.ModelDocument
Dim oModelTitle As String
oModelTitle = oRefDoc.PropertySets("Summary Information").Item("Title").Value
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName &"-"& iProperties.Value("Custom", "pos. nr.") &"   "& "Rev" &"."& oRevNum & "-" & "Sheet." & iSheetNumber & “   “ & oModelTitle & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Next
'------end of iLogic-------
Replies (7)
Message 2 of 8
A.Acheson
Hi @maskintegning_dk
It sounds like the drawing wasn't saved after  the rev was changed, could that be the case?
I would suggest to ensure the drawing is saved before you start the export.
After you get the drawing  object save the drawing like this.
oDrawing.Save
Troubleshooting:
After you get the rev number you can check its value with a messagebox
MessageBox.Show(oRevNum)
 At the end of the rule you can check also what the filename is by placing String value into a messagebox
MessageBox.Show(oDataMedium.FileName)
Regards
Alan
Message 3 of 8
maskintegning_dk
@A.Acheson
Hi Alan.
Thank you for replying.
I have the rule in the Manage -> Event Triggers "After save".
Inventor saves the .idw correctly before the export to PDF. No problems there.
The problem occurs when I run the export rule.
In the Windows browser, the name of the PDF doesn't get updated to Rev.G.
So the result is that when I open the PDF, the correct Rev.G is printet
but in the Windows browser the PDF is still named Rev.F.
Yours sincerely, Lars
Message 4 of 8
A.Acheson
I wasn't able to get the error your seeing when testing with Inventor 2020. Here is the same rule shorten up a little and objects fully declared.
'Define the drawing.
Dim oDrawing As DrawingDocument = ThisDoc.Document
Dim oPath As String = ThisDoc.Path
Dim oFileName As String = iProperties.Value("Custom", "sags nr.")
Dim oPosName As String = iProperties.Value("Custom", "pos. nr.")
Dim oRevNum As String= iProperties.Value("Project", "Revision Number")
Dim oPDFAddIn As ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Step through each drawing sheet.
For Each oSheet As Sheet In oDrawing.Sheets
	'Find the seperator in the sheet name:number.
	Dim lPos As Long = InStr(oSheet.Name, ":")
	'Find the number of characters in the sheet name.
	Dim sLen As Long = Len(oSheet.Name)
	'Find the sheet name.
	Dim sSheetName As String = Left(oSheet.Name, lPos -1)
	'Find the sheet number.
	Dim iSheetNumber As Integer = Right(oSheet.Name, sLen -lPos)
	'Set PDF Options.
	If oPDFAddIn.HasSaveCopyAsOptions(oDrawing,oContext, oOptions) Then
	'Get PDF target folder path.
	Dim oFolder As String = Left(oPath, InStrRev(oPath, "\")) & "PDF"
	'Check for the PDF folder and create it if it does not exist.
	'Get title From model iProperties.
	Dim oRefDoc As Document = ThisDrawing.ModelDocument
	Dim oModelTitle As String = oRefDoc.PropertySets("Summary Information").Item("Title").Value
	oDataMedium.FileName = oFolder & "\" & oFileName & "-" & oPosName &"   "& "Rev."  & oRevNum & "-Sheet." & iSheetNumber & "   " & oModelTitle & ".pdf"
	'Publish document
	oPDFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium)
Next
Regards
Alan
Message 5 of 8
maskintegning_dk
@A.Acheson
Hi Alan.
Thank you for your effort. Much obliged.
I copied your code in to Inventor, but it keeps on overwriting the same file.
I'm thinking that it's a Windows setup problem now.
Thank you again.
Kind regards, Lars
Message 6 of 8
maskintegning_dk
@A.Acheson
Hi Alan.
Did you try the rule in Inventor 2024?
It seems like Inventor locks the very first name to the .idw when saving to PDF
Kind regards, Lars
Message 7 of 8
A.Acheson
I do not use 2024 so cannot test.
Maybe you can disable the pdf export and focus only on the filename output. Is it what you expect?
    Logger.Info(oDataMedium.FileName)
Regards
Alan
Message 8 of 8
maskintegning_dk
@A.Acheson
Hi Alan.
Sorry no. It didn't work.
I replaced the old line with yours in pdf-rule.
Inventor is still overwriting the old pdf.
I wonder why the rule works in Inventor 2020 and not 2024.
Mayby Autodesk have done some new coding in 2024?
Kind regards
Lars
