Inventor Weld Length Data Summation
steveh3
Advisor Advisor
steveh3
Gang...
Trying to create some ilogic to sum the total of all weld lengths in a weldt.
I have the logic running....but I am questioning the accuracy.
Here's the logic....
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oComdef As WeldmentComponentDefinition
oComdef = oDoc.ComponentDefinition
Parameter("Weld_Length_Sum") = 0
Dim oWeldBead As WeldBead
Dim oWeld As Weld
For Each oWeld In oComdef.Welds
	If oWeld.Type = ObjectTypeEnum.kWeldBeadObject Then
	oWeldBead = oWeld
	Logger.Info("some info about the stuff that just happened...")
	Logger.Info(oWeldBead.BeadLength)
	MessageBox.Show((oWeldBead.BeadLength), "weld")
	Parameter("Weld_Length_Sum") = Parameter("Weld_Length_Sum") + (oWeldBead.BeadLength)
	End If
Next
MessageBox.Show(Parameter("Weld_Length_Sum"), "Sum of All Welds")
I get a grand total of 76.48 inches....but if I export the weld bead table....I get a different summation.
The weld bead table is correct, iLogic is wrong.
See the attached spreadsheet for the comparison.
Do I have the correct variable for the bead length?
Thanks in advance,
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
daltonNYAW9
Sorry to do it to ya...
1 inch = 2.54 cm
steveh3
LOL...
That gets me everytime! 🤣
Appreciate the help!
Steve Hilvers
