Inventor vba, is it possible to get User Defined properties and insert them elsewhere?
pklWNF89
pklWNF89
Hi guys.
Is it possible to get the value of a property and insert it elsewhere?
This don't work:
Dim oValue as integer
Set oValue = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("LengthValue")
Dim LV2 as property
Set LV2 = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("LengthValue2")
LV2.Value = oValue
JelteDeJong
try this:
Dim oValue As Object
oValue = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("LengthValue").Value
Dim LV2 As Inventor.Property
set LV2 = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("LengthValue2")
LV2.Value = oValue
and for more information have a look at this page. Here you will also find how to create an iProperty if its not in the document jet.
Jelte de Jong
Blog: hjalte.nl - github.com
pklWNF89
It don't work
I keep getting the same error Run-time error '424' Object required
JelteDeJong
I expect that this is not all of you code because you did not set oDoc. There for i assumed that you only posted a part of the code that is failing. A complete code would look something like this:
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim LV1 As Inventor.Property
set LV1 = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("LengthValue")
LV2.Value = LV1.Value
Just a warning i'm not in the position that i can test this code now. if it still does not work i have to come back for this later.
Jelte de Jong
