Inventor Vb.Net Propert
isocam
isocam
Can anybody help?
I am using the following Vb.Net code to get the values of certain values using PropertySets....
Sub GetPartTypeProperty(oDoc)
   PartType = oDoc.PropertySets.Item(3).Item(17).Value
End Sub
Sub GetPartNumberProperty(oDoc)
   PartNumber = oDoc.PropertySets.Item(3).Item(2).Value
End Sub
Sub GetPartDescriptionProperty(oDoc)
   PartDescription = oDoc.PropertySets.Item(3).Item(14).Value
End Sub
Sub GetPartMaterialProperty(oDoc)
   PartMaterial = oDoc.PropertySets.Item(3).Item(10).Value
End Sub
Does anybody know how I can set the property sets for "Part Type", "Part Number", "Part Description" and "Part Material"
Many thanks in advance!
Darren
Frederick_Law
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-E789B421-6231-486F-ACAB-BEE31A8E9454
This iLogic will list all the names.  Some of them has different display and internal name.  Internal name is the the one use for program.
Sub Main()
Dim oPropsets As PropertySets
Dim oPropset As PropertySet
Dim oProp As Inventor.Property
Dim oDoc As Document
oDoc = ThisDoc.Document
oPropsets = oDoc.PropertySets
For Each oPropset In oPropsets
	Logger.Info("+" & oPropset.DisplayName)
	Logger.Info("-" & oPropset.Name)
	For Each oProp In oPropset
		Logger.Info(" +" & oProp.DisplayName)
		Logger.Info(" -" & oProp.Name)
	Next
Next
End Sub
WCrihfield
Hi @isocam.  The Part Number and Description properties are ReadWrite, but I believe the other two are ReadOnly.  Many of the properties in those first 3 PropertySet objects are ReadOnly, and their values are set internally.
You can review the following Enum documentation for more details about PropertySets.Item(3) (aka Design Tracking Properties)
PropertiesForDesignTrackingPropertiesEnum
Wesley Crihfield
(Not an Autodesk Employee)
JelteDeJong
You might want to have a look at this page: "Accessing iProperties". Apart from that I would do this:
Sub Main()
    Document = ThisDoc.Document
    ' Set propertie
    PartNumber = DateTime.Now().ToString()
    Description = "www.hjalte.nl"
    ' Get properties
    MsgBox(PartType)
    MsgBox(Description)
    MsgBox(PartNumber)
    MsgBox(Material)
End Sub
Public Property PartType() As String
    Get
        Return GetProperty("Design Tracking Properties", "Document SubType Name")
    End Get
    Set(ByVal value As String)
        SetProperty("Design Tracking Properties", "Document SubType Name", value)
    End Set
End Property
Public Property PartNumber() As String
    Get
        Return GetProperty("Design Tracking Properties", "Part Number")
    End Get
        SetProperty("Design Tracking Properties", "Part Number", value)
    End Set
End Property
Public Property Description() As String
    Get
        Return GetProperty("Design Tracking Properties", "Description")
    End Get
        SetProperty("Design Tracking Properties", "Description", value)
    End Set
End Property
Public Property Material() As String
    Get
        Return GetProperty("Design Tracking Properties", "Material")
    End Get
        SetProperty("Design Tracking Properties", "Material", value)
    End Set
End Property
Public Property Document As Document
Public Function GetProperty(setName As String, name As String) As String
    Return Document.PropertySets.Item(setName).Item(name).Value
End Function
Public Sub SetProperty(setName As String, name As String, value As String)
    Dim propertySet = Document.PropertySets.Item(setName)
    Try
        propertySet.Item(name).Value = value
    Catch ex As Exception
        propertySet.Add(value, name)
    End Try
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
