Inventor rule does not work anymore
morrenengineering
morrenengineering
Dear members,
I had this rule like under, but it does not work since the last update. Can someone help me
This error is given
Error in rule: bevestigingsmaterialen-OFF, in document: C152.iam
Object reference not set to an instance of an object.
Dim assemblyDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim occ As Inventor.ComponentOccurrence
For Each occ In assemblyDef.Occurrences.AllLeafOccurrences
    Dim refDoc As PartDocument = occ.Definition.Document
    Dim customPropSet As PropertySet
    customPropSet = refDoc.PropertySets.Item("Inventor User Defined Properties")
	Dim weightProp As Inventor.Property
	weightProp = Nothing
	Try
		weightProp = customPropSet.Item("art")
    Catch ex As Exception
	End Try
    weightVal = weightProp.Value
        If weightVal = "BEV" Then
            occ.Visible = False
        Else
            occ.Visible = True
Next
JelteDeJong
i expect that there is an part without a iProperty "art". try this rule and you will know for sure:
    Dim customPropSet As PropertySet = refDoc.PropertySets.Item("Inventor User Defined Properties")
	Try
		MsgBox("Could not find iProperty 'art' in part " & refDoc.DisplayName)
	End Try
    If weightProp Is Nothing Then continue For
        occ.Visible = False
    Else
        occ.Visible = True
Next
Jelte de Jong
Blog: hjalte.nl - github.com
