How to change iAssembly row through iLogic
kschaffroth1
kschaffroth1
I have an iAssembly with 3 different variations that I would like to change through a user parameter, but in iLogic the function ChangeRow and FindRow I don't seem to work in this case because it is looking for an iPart specifically.
Any ideas?
A.Acheson
The ilogic snippet works for this. Either use  iPart or iAssembly. Ensure you stabilize the browser node  otherwise ilogic will not be able to find the file once the member has been changed. This is likely what is happening for you.
https://www.cadlinecommunity.co.uk/hc/en-us/articles/202020161-Inventor-2014-iLogic-Stabilise-Browse...
https://forums.autodesk.com/t5/inventor-forum/ilogic-change-row/td-p/5118180
If you are wanting to dive into controlling the iassembly factory more there is the API help available online
https://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-5804204C-FE9F-484C-80C0-83AB76824BEA
and also with your install.
Regards
Alan
kschaffroth1
Can you elaborate a little more on the second one with the iAssemblyMember.Row property and how I can use that? You have an assembly with iAssemblies within it, but I am looking to change the row on the iAssembly I am in at that time. Not within another assembly.
A.Acheson
It sound like you want to change the members within the iAssembly factory. The rule below does that and it also does it for an iPart factory as well. I have left in commenting to show you what can be done with the rule. If you are looking to change iProperties via the rule you will need additional pieces of code to get around system generating messages.
Here are a few links that help me generate the below.
https://forums.autodesk.com/t5/inventor-customization/automate-idw-drawing-file-creation-for-all-ipa...
http://inventortrenches.blogspot.com/2013/03/determine-file-type-for-ilogic-rule.html
Sub Main
	Check = MessageBox.Show("Loop through factory members, This will take a while. Are you sure?" _
	, "Ilogic Instructions", MessageBoxButtons.YesNo, MessageBoxIcon.Warning)
	If  Check = vbYes Then
		Dim oDoc As Document
		oDoc = ThisDoc.Document
		If oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
			'Check if ODoc is a Part Document
		   'MessageBox.Show("This is a part file.", "iLogic")
			'Set a reference to the component definition
			oDef = ThisApplication.ActiveEditDocument.ComponentDefinition
			'Make sure we have an iPart factory.
		    If oDef.IsiPartFactory  = False Then
		        MsgBox ("Chosen document is not a factory.", vbExclamation)
		        Exit Sub
			' Set a reference to the factory.
			Dim oFactory As iPartFactory
			oFactory = oDef.iPartFactory
			'Get the number of rows in the factory.
			Dim iNumRows As Integer
			iNumRows = oFactory.TableRows.Count
			Dim iRow As Integer
			'Set iRow = First Member
			oStart = InputBox("Pick a Start Row", "Member Start Row#", 1)
			oEnd = InputBox("Pick a Start Row", "Member Start Row#", iNumRows)
			If oStart = "" Then
				If 	oEnd = "" Then
					Exit Sub
			For iRow = oStart To oEnd
				'Change ipart Row
				iPart.ChangeRow("", iRow)
				'Use if memberfile name needed
				MemberFileName = oFactory.FileNameColumn(iRow).Value
				MessageBox.Show(MemberFileName, "Title")
				'[---Call external "function" or rule or do something--
					'Use if required
				'ThisDoc.Document.Rebuild()
				'Create each member
'					Try
'					 	Call oFactory.CreateMember
'					 Catch
'						MessageBox.Show("Error creating Member", "iLogic")
'					 End Try
				Next
				iLogicVb.UpdateWhenDone = True
					'open folder
				'oFolder = ThisDoc.Path &"\" & ThisDoc.FileName(False)
				'Call Shell("explorer.exe" & " " & oFolder, vbNormalFocus)
			ElseIf oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
			   'MessageBox.Show("This is a Assembly file.", "iLogic")
			    If oDef.IsiAssemblyFactory  = False Then
			        Exit Sub
				Dim oFactory As iAssemblyFactory
				oFactory = oDef.iAssemblyFactory
				'iPartF = oDef.iPartMember.ParentFactory
				Dim iRow As Integer
				oEnd = InputBox("Pick a Start Row", "Member End Row#", iNumRows)
				If oStart = "" Then
					If 	oEnd = "" Then
						Exit Sub
					'Change iassembly Row
					iAssembly.ChangeRow("", iRow)
					'[---Call external "function" or rule or do something---
						'Use if required
					'Create each member
	'					Try
	'					 Catch
	'					 End Try
				Next
						'open folder
	Else
End Sub
Regards
Alan
A.Acheson
Previous Post
"Can you elaborate a little more on the second one with the iAssemblyMember.Row property and how I can use that? You have an assembly with iAssemblies within it, but I am looking to change the row on the iAssembly I am in at that time. Not within another assembly. "
The previous post I put up was more for processing  contents  of the factory file but in reality the snippet below is all that is needed to change the member factory file.
iPart.ChangeRow("", "Member Name")
Can you post a sample file showing the workflow your using , or screenshots.
Regards
Alan
kschaffroth1
That works! Thank you! Interesting how the first quotation marks have to be empty to change it, never would have thought of that. This will be very helpful. And I would show you what I am working on, however, it is on my computer at work and I am not at work until Monday.
