Inventor Macro to Insert an Image
andrew.galbreath
Message 1 of 11
andrew.galbreath
I am using Inventor 2019, and I have multiple .idw files with multiple .png files to be inserted into each of them.
I know how to do this manually: Manage Tab -> Insert Palette -> Insert Object -> Create from File ->Browse -> Select the applicable file
But I haven't found any information on how to do this with a macro, so I'm not sure if it is even possible. Once I know how to do one using a macro, I can easily iterate it to do everything I need.
Any help or information would be greatly appreciated.
Thanks in advance,
-Andrew
Replies (10)
Message 2 of 11
JhoelForshav
Hi @andrew.galbreath
Try this macro 🙂
Sub InsertImage()
Dim doc As Inventor.Document
Set doc = ThisApplication.ActiveDocument
Dim oImagePath As String
oImagePath = "C:\Users\Jhoel\Testimage.png"
'Use the path to your image
Dim oleReference As ReferencedOLEFileDescriptor
Set oleReference = doc.ReferencedOLEFileDescriptors.Add(oImagePath, OLEDocumentTypeEnum.kOLEDocumentEmbeddingObject)
oleReference.BrowserVisible = True
oleReference.Visible = True
oleReference.DisplayName = Mid$(oImagePath, InStrRev(oImagePath, "\") + 1)
End Sub
Message 3 of 11
j_steenbergen
nvm
Message 4 of 11
andrew.galbreath
This does exactly what I need, as far as I can tell.
Thank you so much for the help!
Message 5 of 11
JSutherKAIDI
Hello @JhoelForshav,
Is it possible to set the following:
-> insertion point
-> scale
-> send to back
I have to create spec sheets for many products, following a template. This entails rendering a nice 4K cover image as PNG in the studio environment, embedding it on the front page of an IDW, and manually resizing it to consume all white space (so, so frustrating that images cannot be constrained in IDW). My goal would be insert and scale via ilogic so the placement is consistent.
Thanks!
Message 6 of 11
JhoelForshav
Hi @JSutherKAIDI
Unfortunately I don't think there is any API exposed for this.
https://forums.autodesk.com/t5/inventor-customization/programing-with-ole-image/td-p/3749725
It's an old thread but I can't find anything suggesting that it's not the same today.
Hopefully, if I'm wrong, someone will correct me 🙂
Message 7 of 11
JSutherKAIDI
Understandable, thanks for the response!
Message 8 of 11
amaragkoudakis
This is helpful. Thank you.!
Using your code I am trying to move the image and set a new location into the sheet. Can you help me?
Message 9 of 11
gerrardhickson
So, there doesn't appear to be any way to insert and move an OLE File reference via the API.
As a work around, I figured that you can add the OLR File Reference into a sketched symbol, then move and re-size the sketched symbzHope this helpsol.
Here's some example code:
Sub InsertImageasSketchSymbol()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSkSymDef As SketchedSymbolDefinition
Set oSkSymDef  = oDoc.SketchedSymbolDefinitions.Add("YOUR_SKETCH_SYMBOL_NAME")
Dim oPoint2d As Point2d
'Suggest adding your image at coordinate 0,0. You may like to revise this to suit your application.
Set oPoint2d = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
Dim oImgFN As String
oImgFN = "C:\YOURFILENAME.PNG"
Dim oSK As DrawingSketch
Set oSK = Nothing
oSkSymDef .Edit oSK
oSK.SketchImages.Add oImgFN, oPoint2d, False
oSkSymDef .ExitEdit
Dim oSkSym as SketchedSymbol
set oSkSym = oDoc.ActiveSheet.SketchedSymbols.Add (oSkSymDef , oPoint2d)
'Then oSkSym is the object you can manipulate to suit your application.
End Sub
Hope this helps.
Message 10 of 11
Darkforce_the_ilogic_guy
can you give me an version of your code where the users select the file and maybe scale down a bit ? maybe the width scale down to 1/4 of the selecte papir size
Message 11 of 11
Ralf_Krieg
Hello
Try this one. Don't forget to add the reference to the Microsoft Scripting Runtime in VBA Editor --> Tools --> References or it will fail.
'Add a reference to Microsoft Scripting Runtime !!!
oImgFN = OpenFileDlg '"C:\YOURFILENAME.PNG"
If oImgFN = "" Then Exit Sub
Dim fso As New FileSystemObject
Dim sExt As String
sExt = "." & fso.GetExtensionName(oImgFN)
Dim sPicName As String
sPicName = Replace(fso.GetFileName(oImgFN), sExt, "")
On Error Resume Next
Set oSkSymDef = oDoc.SketchedSymbolDefinitions.Add("Pic_" & sPicName)
If Err.Number <> 0 Then
    Set oSkSymDef = oDoc.SketchedSymbolDefinitions.item("Pic_" & sPicName)
Set oSK = Nothing
oSkSymDef.Edit oSK
oSkSymDef.ExitEdit
Dim oSkSym As SketchedSymbol
Set oSkSym = oDoc.ActiveSheet.SketchedSymbols.Add(oSkSymDef, oPoint2d, 0, 0.25) '<------ 0 is the rotation, 0.25 is the scale factor
End Sub
Private Function OpenFileDlg() As String
    ' Create a new FileDialog object.
    Dim oFileDlg As FileDialog
    Call ThisApplication.CreateFileDialog(oFileDlg)
    ' Define the filter to select part and assembly files or any file.
    'oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
    oFileDlg.filter = "All Image Files|*.bmp;*.gif;*.jpg;*.png;*.tif|BMP (*.bmp)|*.bmp|GIF (*.gif)|*.gif|JPEG (*.jpg)|*.jpg|PNG (*.png)|*.png|TIFF (*.tif)|*.tif"
    ' Define the part and assembly files filter to be the default filter.
    oFileDlg.FilterIndex = 1
    ' Set the title for the dialog.
    oFileDlg.DialogTitle = "Open File Test"
    ' Set the initial directory that will be displayed in the dialog.
    oFileDlg.InitialDirectory = "C:\"
    ' Set the flag so an error will be raised if the user clicks the Cancel button.
    oFileDlg.CancelError = True
    ' Show the open dialog.  The same procedure is also used for the Save dialog.
    ' The commented code can be used for the Save dialog.
    oFileDlg.ShowOpen
'    oFileDlg.ShowSave
    ' If an error was raised, the user clicked cancel, otherwise display the filename.
    If Err Then
        MsgBox "User cancelled out of dialog"
        OpenFileDlg = ""
    ElseIf oFileDlg.fileName <> "" Then
        'MsgBox "File " & oFileDlg.filename & " was selected."
        OpenFileDlg = oFileDlg.fileName
End Function
R. Krieg
RKW Solutions
www.rkw-solutions.com
