Create Sketch From Extrude Feature
While create the Extrude feature from Sketch entities, some of the closed area does not convert as Solid during the Extrude process.So i need to identify all the entities are converted as solid or not.
For this case, i need to create the sketch from Extrude feature. Since i need to compare the two sketch entities.
So kindly guide me how to create Sketch using Extrude feature?
Otherwise how to create the profile shape by projecting a solid?
WCrihfield
Have you tried playing around with the Sketch.Profiles.AddForSolid() function's optional settings?
For example:
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oSketch As PlanarSketch = oPDef.Sketches.Item(1)
Dim oProfilePathSegments As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oProfileOption As Profile In oSketch.Profiles
	If oProfileOption.RegionProperties.Area = 56 Then
		oProfilePathSegments.Add(oProfileOption)
Next
Dim oProfile As Profile = oSketch.Profiles.AddForSolid(False,oProfilePathSegments)
Dim oExtFeats As ExtrudeFeatures = oPDef.Features.ExtrudeFeatures
Dim oExtDef As ExtrudeDefinition = oExtFeats.CreateExtrudeDefinition(oProfile,PartFeatureOperationEnum.kNewBodyOperation)
Dim oExtFeat As ExtrudeFeature = oPDef.Features.ExtrudeFeatures.Add(oExtDef)
Wesley Crihfield
(Not an Autodesk Employee)
Thanks for the reply.
But i need to create sketch from Part or Extrude feature.
(since i need to confirm whether all closed skecth profiles are converted as Part)
Is it possible?
