Inventor macro – Export workpoints to CSV file inside assembly
hreuvers
hreuvers
Macro's for IPT support are commonly available, here a modified version with (multi-level) assembly support.
- XYZ coordinates of work points relative to origin of main assembly will be exported to a CSV file
- Works with parts in sub-assemblies and in sub-sub-assemblies (3 levels)
- Work points inside suppressed parts/ assemblies are excluded
- Visibility state of work point will be ignored (non-visible work points will be exported)
- Filter work points with (partial) name of the work point (e.g. “center” for “Center Point”)
See attachments for more information...
adam.nagy
Autodesk Support
Autodesk Support
I'm just trying to make sure I'm not misunderstaning somthing 🙂
You simply uploaded this as a sample or are you having some issues you need help with?
Cheers,
Adam Nagy
Autodesk Platform Services
hreuvers
It is a full working macro with an example!
Because I used some routines from other sources,
I would like to share this with others too!
Just giving back to the communitySmiley Happy
Dude!  I know this is an old thread, but thanks for taking the time to upload your util - you saved me a metric binload of time.  I couldn't believe my luck finding this, it was exactly what I was looking for.  Like you, I had found a bunch of examples extracting from a part level but the assy level is what the fans want.
matthew_neesley
ErmaGERD this is unbelievably AWESOME 🙂
I am getting "Run-time error '-2147467259 (80004005)': Method 'Definition' of object 'ComponentOccurence' failed. Any idea what is going on? Thanks
