Inventor is Loading Two different .ipt Templates
I recently upgraded to Inventor Professional 2019 and it's been giving me fits on my default templates. I've ironed out the kinks in the sheet metal template, however the part .ipt template is confusing me.
If I click on File, hover over "New" and select part it loads a mystery default template that I cannot find.
If I click on File, click "New', and select part from the dialogue window it loads the default template I want.
How can I correct this so both paths select the correct default template?
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
If I click on File, hover over "New" and select part it loads a mystery default template that I cannot find - It works only when template name in custom template path should be "Standard.ipt".
For more details, refer below blog article link.
https://www.trainingtutorial.com/TAT68_Inventor_Templates_Standard_and_Custom.htm
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
