iLogic: Is not equal to
attempting to run ilogic code if a certain cell value i am pulling from is not equal to something - how would i do this?
this is what i tried:
SyntaxEditor Code Snippet
Attach = GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "D3")
If Attach = Not("NONE") Constraint.IsActive("Mate:Attach") = True End If
but it returns with the error:  Conversion from string "NONE" to type 'Long' is not valid.
is not() the wrong code for this?
Lewis.Young
Try this:
If Not Attach = ("NONE")
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
mcgyvr
= equals
<> not equal to
https://docs.microsoft.com/en-us/dotnet/visual-basic/language-reference/operators/comparison-operato...
this worked perfectly! thanks
SER4
If you need a "neither nor" aka a "not or", use this setup:
If Not (ThisApplication.ActiveDocumentType = kPartDocumentObject Or ThisApplication.ActiveDocumentType = kAssemblyDocumentObject) Then
I.e. if you need to check that something is NOT within a set of things; use the Not out front, then in brackets put the various equals expressions.
P.Eng. Mechanical Engineer
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2025.1 (30.1.63.0); Inventor Pro 2025.1.1 (241).
