Inventor Drawing iLogic to save as model user parameter file name
Hi All,
drawing rule:
SyntaxEditor Code Snippet
FilePath = "W:\M&R Plating"
If (Not System.IO.Directory.Exists(FilePath)) Then
	System.IO.Directory.CreateDirectory(FilePath)
ThisDoc.Document.SaveAs(FilePath & "\" & ThisDoc.FileName(False) & ".pdf", True)
ThisDoc.Document.SaveAsInventorDWG(filePath & "\" & ThisDoc.FileName(True), True)
 How can I replace ThisDoc.FileName above with the user parameter partNumber from the .ipt file?
2018-11-29 10_27_24-Autodesk Inventor Professional 2019 - [Scorer Head].pngThank you
JamieVJohnson2
Get the Parameter by its name from the active document's ComponentDefinition's Parameters collection.  Then use the parameter's value as the variable in your code.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Hi Jamie, thanks for your help.  I'm trying to do this from the drawing file and access the model's parameter.  I'm fairly new to this, so correct me if i'm off base, but this would not be the active document, correct?
Dim partNum As String
partNum = Parameter("Scorer Head.ipt", "partNumber")
MessageBox.Show(partNum)
'ThisDoc.Document.SaveAs(ThisDoc.FileName(True), True)
'ThisDoc.Document.SaveAsInventorDWG(FilePath & "\" & ThisDoc.FileName(True), True)
ThisDoc.Document.SaveAsInventorDWG(FilePath & "\" & partNum, True)
This displays the parameter correctly in the message box, but it won't pull the value into the saveas path.
i get this error:  The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
JamieVJohnson2
Looks like your close here then.  What needs to happen next is you need to construct a file path string that uses partNum for your saveas command.  While your method should work, I have separated it from the saveas command to be sure it is what I wanted.
  Example:
dim strFileExtension as string = system.io.Path.GetExtension(ThisDoc.FileName) 'should return something like '.idw'
Dim strNewFilePath as string = FilePath & "\" & partNum & strFileExtention
'make sure file path is correct before assuming:
msgbox(strNewFilePath)
ThisDoc.Document.SaveAsInventorDWG(strNewFilePath, True)
Hi Jamie,  I appreciate the help.  It still doesn't seem to like using a variable as the file path for SaveAsInventorDWG.  It works perfectly if i use SaveAs and type in the .idw or .dwg...the problem here is it defaults the dwg to exporting a acad dwg and i am needing inventor dwg.  This also works fine:
 i think this is a bug and may have to just stick to using .idw
Counter intuitive, but this worked!
ThisDoc.Document.SaveAs(FilePath & "\" & partNum & ".pdf", True)
ThisDoc.Document.SaveAsInventorDWG(FilePath & "\" & partNum & ".DWG", True)
trigger = iTrigger0
