Inventor defaults.xml - Collect machine user name on open .
luismestre
luismestre
Hi all
How do I edit the  line code in inventor defaults.xml  file ?
I want Inventor to collect the machine user name and added it in Options>General>user name .
Inventor defaults.xml file is shared within a team of  30 users.
Is this possible to do?
Regards
Luis Mestre
Luis Mestre
Oil&Gas Sr.3D & Subsea/Structural Designer
"Autodesk Autocad/Inventor & 3D Studio Max"
Email:lmsmestre@gmail.com
Ktomberlin
You can use notepad, but I have been using XML Notepad (http://xmlnotepad.codeplex.com/). Much easier for editing the configuration files, as well as parameter files you need to export, edit and import. Kevin
luismestre
Hi Kevin
I use notepad as well to edit the files.
My question was about the code line.
Can you help?
Regards
Luis Mestre
Luis Mestre
Ktomberlin
Well this doesn't edit the xml directly, but it does change the user name in options.   This might accomplish what your trying to do.
Code Snippet
WSHnet = CreateObject("WScript.Network")
UserName = WSHnet.UserName
UserDomain = WSHnet.UserDomain
objUser = GetObject("WinNT://" & UserDomain & "/" & UserName & ",user")
'get user name
UserFullName = objUser.FullName
ThisApplication.GeneralOptions.UserName = UserFullName
luismestre
Hi
Do I h;ave to run the code as a vb macro?
If so all users will be able to load the macro at start up,  correct?
Luis Mestre
