auto update all styles in ipt
Message 1 of 9
Good afternoon,
     Looking for vba code that would automatically update all styles when you open a ipt.  If anyone would be willing to share that would be great.
Thank you.
Replies (8)
Message 2 of 9
sajith_subramanian
Autodesk Support
Autodesk Support
Hi fishermanfry,
Below is a piece of Ilogic code that may be something similar to what you are looking for.
If ThisApplication.ActiveDocumentType = kPartDocumentObject Then
    Dim doc As PartDocument
    doc = ThisApplication.ActiveDocument
    Dim style As LightingStyle
    For Each style In doc.LightingStyles
        If style.UpToDate = False Then
         style.UpdateFromGlobal
    Next
If you want this rule to run automatically when an ipt is opened, you can hook it up to the "After Open Document" trigger.
Let me know if this helps.
Sajith
Sajith Subramanian
Autodesk Developer Network
Message 3 of 9
reine_den_andra
Hi
I cant´t make this work.
Can you try to specify little more?
I am making a new rule with this and make a trigger for it, but I cant make it work.
I am using Inventor 2019.
/Reine
Message 4 of 9
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @reine_den_andra,
Once you create your rule, navigate to Manage -> Event Triggers. This will show up a new dialog as shown below
Now you will see the rule you created in the left panel. Click and drag it over to the required event (in this case, I have dragged it to the "After Open Document"). Your rule will then show up on the right tab under the selected event.
Your rule should now be automatically triggered when the selected event fires.
Hope this helps.
Sajith
Sajith Subramanian
Message 5 of 9
reine_den_andra
Hi
Yes, I have done all that. But when I open an old part the rule is not there?
It is only there when I create an new part.
/Reine
Message 6 of 9
sajith_subramanian
Autodesk Support
Autodesk Support
Not sure if I understood your question, but are you using an external rule in your case? Otherwise it would be applicable only for the open document.
Sajith
Sajith Subramanian
Message 7 of 9
reine_den_andra
Hi
Ok, lets start over. 😁
When I open and old part with old styles.
I want that old part to auto update all styles to match my styles library.
Is that possible?
/Reine
Message 8 of 9
sajith_subramanian
Autodesk Support
Autodesk Support
Yes, it should be possible. You would need to call the UpdateFromGlobal API from the required object.
Now for example, in the case of materials :
https://forums.autodesk.com/t5/inventor-customization/updatefromglobal-for-materials/m-p/5102012/hig...
Sajith
Sajith Subramanian
