Inventor crashing with new 3D Annotations in drawing
DWhiteley
Advisor Advisor
Message 1 of 8
DWhiteley
I have found that Inventor 2018 crashes when using GetRetrievableDimensions if the model document contains the new 3D Annotations:
Dim oDims As GeneralDimensions
oDims = osheet.DrawingDimensions.GeneralDimensions
For Each oView In oViews
  oRetDims = oDims.GetRetrievableDimensions(oView)
(Works fine in 2017)
Dave Whiteley
Envisage UK Ltd
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Dave,
Please try the following sample code.
oDims = oSheet.DrawingDimensions.GeneralDimensions
For Each oView in oViews
      Dim objColl As ObjectCollection
      objColl = oDims.GetRetrievableDimensions(oView)
Next
If still Inventor crashes, then please provide document which contains 3 D annotation.
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" / give a kudo.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
DWhiteley
Hi Chandra,
I just took out the line oRetDims = oDims.GetRetrievableDimensions(oView)
This fixed my problem of Inventor 2018 crashing:
 ''oRetDims = oDims.GetRetrievableDimensions(oView)
 ''If oRetDims.Count > 0 Then
 Try
   Dim dimsEnum As GeneralDimensionsEnumerator
   dimsEnum = oDims.Retrieve(oView)
 Catch ex As Exception
 End Try
Next
I still believe there is a problem with GetRetrievableDimensions with parts that have 3D annotation added to them.
Dave
Message 4 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Dave,
Can you please specify about declaration of oRetDims variable?
Actually, GetRetrievableDimensions(oView) method returns ObjectCollection. So, oRetDims should be declared as ObjectCollection.
Please provide 3d annotation part file, if it is non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 8
DWhiteley
Dim oRetDims As ObjectCollection
Model attached.
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Dave,
I can also reproduce crash, if the model contains tolerance feature annotations.
So, I checked with engineering team. It is a known issue.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 8
DWhiteley
Ok, thanks Chandra. Is this likely to be fixed soon?
Dave
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Message 8 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Dave,
Yes, It will be fixed soon.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
