Inventor Crashes editing section view
meck
Message 1 of 1
meck
I'm trying to turn a part's visibility on or off in a drawing view using iLogic code. The rule is in the .dwg with the parts I wish to set.. Everything works great unless the view is a section view then Inventor crashes. No error message is generated it just crashes. Below is my code. If anyone has a suggestion I'd really appreciate it.
Sub Main
        Call PartVisibility("My Occur:1",False,"VIEW1")
End Sub
Public Sub PartVisibility(PartName As String, Visible As Boolean, ViewName As String, Optional AllViews as Boolean = False)
    invApp = GetObject(, "Inventor.Application")
    'Make sure views exist
    Dim Views As DrawingViews
    Views = ActiveSheet.Sheet.DrawingViews
    If Views.count = 0 Then
        Exit Sub
    Call SetActiveDoc("General Assembly.iam")
    'Get the drawing occurance to be set
    Dim oAsmCompDef As AssemblyComponentDefinition
    oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    ' Get references to the two occurrences to constrain.
    ' This arbitrarily gets the first and second occurrence.
    Dim oOcc1 As ComponentOccurrence
    oOcc1 = oAsmCompDef.Occurrences.ItemByName(PartName)
    Call SetActiveDoc("General Assembly.dwg")
    Try
        'On Error Resume Next
        Dim oDrawView As DrawingView
        For Each oDrawView In Views
            If AllViews = False Then
                If UCase(ViewName) = UCase(oDrawView.Name) Then
                    oDrawView.SetVisibility(oOcc1, Visible)
            Else
        Next
    Catch
    'do nothing
    End Try
End Sub
Public Function SetActiveDoc(DocName As String) As Boolean
'This Sets the active document and returns true if sucessful
Dim Dwgs As Documents
 Dwgs = ThisApplication.Documents
Dim Dwg As Document
For Each Dwg In Dwgs
    If Dwg.DisplayName = DocName Then
        On Error Goto hell
        Dwg.Activate
        SetActiveDoc = True
        Exit For
Next
 Dwgs = Nothing
 Dwg = Nothing
Exit Function
hell:
 Dwgs = Nothing
 Dwg = Nothing
SetActiveDoc = False
End Function
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
Replies (0)
