Inventor Can't Connect with Visual Basic
abilabib
Message 1 of 13
abilabib
How to solve this problem. Because Inventor Can't Connect with Visual Basic.
I'm use Inventor 2015 and Visual Studio Express 2015.
Afri
Replies (12)
Message 2 of 13
abilabib
Message 3 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
Before running this code, make sure that Inventor 2015 is launched to connect through Visual basic.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 13
abilabib
@chandra.shekar.g : I've make sure that Inventor 2015 is launched first and then running the code. But this code can't connect with Inventor. Could tell me how to trace this problem ?
Message 5 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
Actually, Inventor 2015 build is unavailable to test for us. Inventor 2015 contains 2 types of dll(Autodesk.Inventor.Interop.dll). One is 32 bit dll for 32 bit application and another one is 64 bit dll. Issue might be due to referencing 32 bit dll in 64 bit application.
Can you please edit MessageBox.Show inside Catch ? So that, it gives idea about what kind of exception that you are getting.
Catch ex as Exception
       MessageBox.Show("Inventor Haras Dalam keadaan Aktif " &  ex.Message)
       Me.Close()
       Exit Sub
End Try
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 13
abilabib
@chandra.shekar.g : Thanks for your reply. I'll try after IED holiday. Because it only happens in the office
Message 7 of 13
abilabib
@chandra.shekar.g :
Here's the message :
(Exception from HRESULT: 0x800401F3 (CO_E_CLASSSTRING))
Message 8 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
If Inventor 32 dll is used, make sure that configuration manager is set to x86 in Visual studio. Similarly, for 64 bit dll, configuration manager should be x64.
Can you please share source code to investigate? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 13
abilabib
@chandra.shekar.g
File attached.
Message 10 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
Sorry for late reply,
Attached source code is tested in my system (Except that unavailability of Inventor 2015)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 13
abilabib
@chandra.shekar.g : Thanks for your reply. But I can't find attached.
Message 12 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
I meant that source code which is attached in previous conversation.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 13
abilabib
@chandra.shekar.g: Oh Ok. I see.
