Inventor CAM can’t access
the.cyclone.alliance
Observer Observer
Observer
Observer
I’ve done all the recommended fixes that I have found online. I know the addin file and .dll are both in the correct position. Still nothing besides one instance it recognized it then blocked it. Any help would be greatly appreciated
  • CAM
JelteDeJong
I'm not entirely sure what you're asking, but it sounds like you have an add-in that isn't loading. When you load an add-in for the first time, it may get blocked in some cases.
You can check and fix this in the Add-in Manager:
  1. Open the Add-in Manager and find your add-in in the list.
  2. Select it, and make sure the checkbox labelled "Blocked" is unchecked.
  3. The other two checkboxes should be checked.
Jelte de Jong
Blog: hjalte.nl - github.com
