Inventor CAM can’t access
the.cyclone.alliance
Observer Observer
Observer
Observer
I’ve done all the recommended fixes that I have found online. I know the addin file and .dll are both in the correct position. Still nothing besides one instance it recognized it then blocked it. Any help would be greatly appreciated
JelteDeJong
I'm not entirely sure what you're asking, but it sounds like you have an add-in that isn't loading. When you load an add-in for the first time, it may get blocked in some cases.
You can check and fix this in the Add-in Manager:
  1. Open the Add-in Manager and find your add-in in the list.
  2. Select it, and make sure the checkbox labelled "Blocked" is unchecked.
  3. The other two checkboxes should be checked.
Jelte de Jong
Blog: hjalte.nl - github.com
