Inventor - Auto balloon picking at end/start point of member, Inst-ed of that need center
pl.sivakumar
Message 1 of 8
pl.sivakumar
I am using Inventor 2021, While drawing preparation,
Auto balloon  picking at end/start point of the member, Inst-ed of that need centre
Replies (7)
Message 2 of 8
A.Acheson
I don’t think there is a setting to change the snap location when using the manually activated command auto balloon  but I could be wrong. Next step is to use ilogic. This may help.
https://forums.autodesk.com/t5/inventor-customization/auto-balloon/td-p/3315209
Regards
Alan
Message 3 of 8
pl.sivakumar
Thanks for your reply,
I found the following error while running this code into iLogic, I tried with macro also still some error on thate.PNG
Message 4 of 8
dutt.thakar
@pl.sivakumar
To fix this error do the following you need to add a subroutine,
Sub Main
     ' Add your code here
End Sub
I would also prefer if you can post your code here, as I see some parts of the code need to be checked once, else you will face other errors.
Hope this will help you.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Message 5 of 8
pl.sivakumar
Public Sub AutomaticBallooning(ByVal rstSTK As ADODB.Recordset)
Try
   Dim oDrawDoc As Inventor.DrawingDocument
   oDrawDoc = m_inventorApplication.ActiveDocument
   Dim oActiveSheet As Inventor.Sheet
   oActiveSheet = oDrawDoc.ActiveSheet
   Dim oPartslist As Inventor.PartsList
   oPartslist = oActiveSheet.PartsLists.Item(1)
   Dim oPartslistRow As Inventor.PartsListRow
   For Each oPartslistRow In oPartslist.PartsListRows
        oPartslistRow.Visible = False
   Next
         If oPartslistRow.Ballooned = FalseThen
            'make row visible so user sees which row is going to ballooned
            oPartslistRow.Visible =True
            Dim strArtnr AsString
            strArtnr = oPartslistRow.Item(4).Value
            CreateBalloonPerOccurencesPerView(strArtnr)
         oPartslistRow.Visible =False
   Next
   ForEach oPartslistRow In oPartslist.PartsListRows
   Next
                    ''Method with Partlist from PDM
                    'Do While rstSTK.EOF = False
                    '    Dim strArtnr As String
                    '    strArtnr = rstSTK.Fields("ARTNR").Value
                    '    CreateBalloonPerOccurencesPerView(strArtnr)
                    '    rstSTK.MoveNext()
                    'Loop
   Catch ex As Exception
       MessageBox.Show(ex.ToString)
   End Try
EndSub
PrivateSub CreateBalloonPerOccurencesPerView(ByVal strArtnr AsString)
       Try
           'loop door de views heen
           Dim oDrawingviews As Inventor.DrawingViews
            oDrawingviews = oActiveSheet.DrawingViews
           Dim oDrawingView As Inventor.DrawingView
           ForEach oDrawingView In oDrawingviews
               Dim oDocDesc As Inventor.DocumentDescriptor
                oDocDesc = oDrawingView.ReferencedDocumentDescriptor
               Dim oAsmDef As Inventor.AssemblyComponentDefinition
                oAsmDef = oDocDesc.ReferencedDocument.ComponentDefinition
               Dim oComponentOccurrence As Inventor.ComponentOccurrence
               ForEach oComponentOccurrence In oAsmDef.Occurrences
                   If oComponentOccurrence.Name.Contains(strArtnr) Then
                       Dim oDrawCurves As Inventor.DrawingCurvesEnumerator
                        oDrawCurves = oDrawingView.DrawingCurves(oComponentOccurrence)
                       Dim DrawCurve As Inventor.DrawingCurve
                       ForEach DrawCurve In oDrawCurves
                           Dim oColorRed As Inventor.Color
                            oColorRed = m_inventorApplication.TransientObjects.CreateColor(255, 0, 0)
                            DrawCurve.Color = oColorRed
                       Next
                       'Call create balloon command and wait till its finished
                       Dim oControlDef As Inventor.ControlDefinition
                        oControlDef =
                                 m_inventorApplication.CommandManager.ControlDefinitions.Item  ("DrawingBalloonCmd")
                       Try
                            oControlDef.Execute()
                       EndTry
                       DoWhile m_inventorApplication.CommandManager.ActiveCommand = "DrawingBalloonCmd"
                            System.Windows.Forms.Application.DoEvents()
                       Loop
                           Dim oColorBlack As Inventor.Color
                            oColorBlack = m_inventorApplication.TransientObjects.CreateColor(0, 0, 0)
                            DrawCurve.Color = oColorBlack
                       Next
               Next
           Next
       EndTry
End Sub
Message 6 of 8
pl.sivakumar
Waiting for feed back
Message 7 of 8
pl.sivakumar
Good morning
Any update please
Message 8 of 8
dutt.thakar
@pl.sivakumar
I have converted the code that will work in iLogic, but are you looking for a solution like this? I am not sure that this will be helpful for you or not.
This is actually running the ballon command and highlighting the components one by one according to their order in the parts list. Please have a look and reply with your thoughts.
Sub Main
Try
   oDrawDoc = ThisApplication.ActiveDocument
   Next
   Next
   Next
                    '    rstSTK.MoveNext()
                    'Loop
   End Try
End Sub
Private Sub CreateBalloonPerOccurencesPerView(ByVal strArtnr As String)
       Try
           For Each oDrawingView In oDrawingviews
               For Each oComponentOccurrence In oAsmDef.Occurrences
                       For Each DrawCurve In oDrawCurves
                            oColorRed = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
                       Next
                        oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item  ("DrawingBalloonCmd")
                       Try
                       End Try
                       Do While ThisApplication.CommandManager.ActiveCommand = "DrawingBalloonCmd"
                       Loop
                            oColorBlack = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
                       Next
               Next
           Next
      Catch
            MessageBox.Show("Exception")
		End Try
End Sub
Dutt Thakar
LinkedIn
