Auto Balloon
Auto Balloon
Auto Balloon
I'm trying to write a program in C# to automate ballooning from a BOM.
The routine must read the BOM and for every row it highlights in all the views the corresponding component.
Then the user must be able to manualy draw a balloon or balloons to the highlighted items.
When done the next row of the BOM is called, etc.
I can choose to start with a BOM from our PDM system or the Inventor BOM, partlist or drawingBOM
I tried different ways but I get stuck on it.
I even tried to select the nodes in the browser and called oNode.doselect, but then I can't get the proper type for the selected items to go further?
What is the best approach?
Does anybody have an example how to do this?
Geert
So I figured this one out myself!
For those who want this, here is my raw VB.net code:
Public Sub AutomaticBallooning(ByVal rstSTK As ADODB.Recordset)
Try
   Dim oDrawDoc As Inventor.DrawingDocument
   oDrawDoc = m_inventorApplication.ActiveDocument
   Dim oActiveSheet As Inventor.Sheet
   oActiveSheet = oDrawDoc.ActiveSheet
   Dim oPartslist As Inventor.PartsList
   oPartslist = oActiveSheet.PartsLists.Item(1)
   Dim oPartslistRow As Inventor.PartsListRow
   For Each oPartslistRow In oPartslist.PartsListRows
        oPartslistRow.Visible = False
   Next
         If oPartslistRow.Ballooned = FalseThen
            'make row visible so user sees which row is going to ballooned
            oPartslistRow.Visible =True
            Dim strArtnr AsString
            strArtnr = oPartslistRow.Item(4).Value
            CreateBalloonPerOccurencesPerView(strArtnr)
         oPartslistRow.Visible =False
   Next
   ForEach oPartslistRow In oPartslist.PartsListRows
   Next
                    ''Method with Partlist from PDM
                    'Do While rstSTK.EOF = False
                    '    Dim strArtnr As String
                    '    strArtnr = rstSTK.Fields("ARTNR").Value
                    '    CreateBalloonPerOccurencesPerView(strArtnr)
                    '    rstSTK.MoveNext()
                    'Loop
   Catch ex As Exception
       MessageBox.Show(ex.ToString)
   End Try
EndSub
PrivateSub CreateBalloonPerOccurencesPerView(ByVal strArtnr AsString)
       Try
           'loop door de views heen
           Dim oDrawingviews As Inventor.DrawingViews
            oDrawingviews = oActiveSheet.DrawingViews
           Dim oDrawingView As Inventor.DrawingView
           ForEach oDrawingView In oDrawingviews
               Dim oDocDesc As Inventor.DocumentDescriptor
                oDocDesc = oDrawingView.ReferencedDocumentDescriptor
               Dim oAsmDef As Inventor.AssemblyComponentDefinition
                oAsmDef = oDocDesc.ReferencedDocument.ComponentDefinition
               Dim oComponentOccurrence As Inventor.ComponentOccurrence
               ForEach oComponentOccurrence In oAsmDef.Occurrences
                   If oComponentOccurrence.Name.Contains(strArtnr) Then
                       Dim oDrawCurves As Inventor.DrawingCurvesEnumerator
                        oDrawCurves = oDrawingView.DrawingCurves(oComponentOccurrence)
                       Dim DrawCurve As Inventor.DrawingCurve
                       ForEach DrawCurve In oDrawCurves
                           Dim oColorRed As Inventor.Color
                            oColorRed = m_inventorApplication.TransientObjects.CreateColor(255, 0, 0)
                            DrawCurve.Color = oColorRed
                       Next
                       'Call create balloon command and wait till its finished
                       Dim oControlDef As Inventor.ControlDefinition
                        oControlDef =
                                 m_inventorApplication.CommandManager.ControlDefinitions.Item  ("DrawingBalloonCmd")
                       Try
                            oControlDef.Execute()
                       EndTry
                       DoWhile m_inventorApplication.CommandManager.ActiveCommand = "DrawingBalloonCmd"
                            System.Windows.Forms.Application.DoEvents()
                       Loop
                           Dim oColorBlack As Inventor.Color
                            oColorBlack = m_inventorApplication.TransientObjects.CreateColor(0, 0, 0)
                            DrawCurve.Color = oColorBlack
                       Next
               Next
           Next
       EndTry
End Sub
