Inventor as a part of FDS - Ui and standard swatches
Logos_Atum
Advisor Advisor
Logos_Atum
Hello there,
i wonder if it´s possible to save a standard Inventor
user interface. I want some of the factory options to appear as standard
and i would also need the "rename browser nodes" Button to appear.
I heard Inventor is alsomst fully customizable but I have no experience
customizing Inventor as i do have in AutoCAD.
I´d be glad if you could help me a little.
Regards
Daniel
Dogs aren´t flammable.
xiaodong_liang
Autodesk Support
Autodesk Support
Did you need the file of all Inventor user interface, or just want to know how to customize Inventor UI? If the latter, I'd recommend the class firstly. I
http://download.autodesk.com/media/adn/Autodesk_Inventor_API_Module9_User_Interface_29April10.zip
And one more advanced class may also help you:
http://au.autodesk.com/?nd=class&session_id=9028
Logos_Atum
Hello there,
thank you for the information. I will have a close look
to let you know if i can work a solution out.
Thank you very much
Kind regards
Daniel
Logos_Atum
Hello there,
customizing Inventor will suffice.
API programming is not needed
yet, but very interesting for sure.
Kind regards
Daniel
