Inventor API Python
Inventor API Python
22351396
Inventor API Python
22351396
I tried to create an assembly joint. It connects the midpoints of the edges of two faces using a rotational joint. I used python.
My problem is that "Error creating joint definition: (-2147352567, 'Exception occurred.', (0, None, None, None, 0, -2147467259), None)"
Here is my code.
import win32com.client
def AssemblyJoint():
    # Initialize Inventor application
    invApp = win32com.client.Dispatch("Inventor.Application")
    # Create a new assembly document
    asmDoc = invApp.Documents.Add(12291, invApp.FileManager.GetTemplateFile(12291, 8962))
    asmDef = asmDoc.ComponentDefinition
    tg = invApp.TransientGeometry
    # Place an occurrence into the assembly
    matrix1 = tg.CreateMatrix()
    translation_vector1 = tg.CreateVector(0, 0, 0)
    matrix1.SetTranslation(translation_vector1)
    occ1 = asmDef.Occurrences.Add("C:\\Users\\MINHAZULISLAM\\Desktop\\API Join\\Part1.ipt", matrix1)
    matrix2 = tg.CreateMatrix()
    translation_vector2 = tg.CreateVector(8 * 2.54, 6 * 2.54, 2 * 2.54)  # Converting inches to cm
    matrix2.SetTranslation(translation_vector2)
    occ2 = asmDef.Occurrences.Add("C:\\Users\\MINHAZULISLAM\\Desktop\\API Join\\Part2.ipt", matrix2)
    # Print the structure of the first occurrence
    print("Occurrence 1:")
    PrintStructure(occ1)
    print("\nOccurrence 2:")
    PrintStructure(occ2)
    # Get faces and edges by index
    face1 = occ1.SurfaceBodies.Item(1).Faces.Item(1)
    face2 = occ2.SurfaceBodies.Item(1).Faces.Item(1)
    edge1 = occ2.SurfaceBodies.Item(1).Edges.Item(1)
    edge3 = occ1.SurfaceBodies.Item(1).Edges.Item(1)
    # Debugging information
    if not face1:
        print("Face1 not found")
    if not face2:
        print("Face2 not found")
    if not edge1:
        print("Edge1 not found")
    if not edge3:
        print("Edge3 not found")
    # Check if the faces and edges were found
    if not face1 or not face2 or not edge1 or not edge3:
        raise ValueError("One or more named entities could not be found.")
    # Create geometry intents
    edge1Intent = asmDef.CreateGeometryIntent(edge1, 1)
    edge3Intent = asmDef.CreateGeometryIntent(edge3, 1)
    intentOne = asmDef.CreateGeometryIntent(face2, edge1Intent)
    intentTwo = asmDef.CreateGeometryIntent(face1, edge3Intent)
    # Debugging information for intents
    print("Edge1 Intent:", edge1Intent)
    print("Edge3 Intent:", edge3Intent)
    print("Intent One:", intentOne)
    print("Intent Two:", intentTwo)
    # Create a rotation joint between the two parts
    try:
        jointDef = asmDef.Joints.CreateAssemblyJointDefinition(102401, intentOne, intentTwo)  # kRotationalJointType
    except Exception as e:
        print("Error creating joint definition:", e)
        return
    jointDef.FlipAlignmentDirection = False
    jointDef.FlipOriginDirection = True
    joint = asmDef.Joints.Add(jointDef)
    # Make the joint visible
    joint.Visible = True
    # Drive the joint to animate it
    joint.DriveSettings.StartValue = "0 deg"
    joint.DriveSettings.EndValue = "180 deg"
    joint.DriveSettings.GoToStart()
    joint.DriveSettings.PlayForward()
    joint.DriveSettings.PlayReverse()
def PrintStructure(occurrence):
    # Print the structure of the occurrence
    partDef = occurrence.Definition
    surfaceBodies = partDef.SurfaceBodies
    print(f"Number of Surface Bodies: {surfaceBodies.Count}")
    for i in range(1, surfaceBodies.Count + 1):
        surfaceBody = surfaceBodies.Item(i)
        print(f"  Surface Body {i}:")
        print(f"    Number of Faces: {surfaceBody.Faces.Count}")
        for j in range(1, surfaceBody.Faces.Count + 1):
            print(f"      Face {j}")
        print(f"    Number of Edges: {surfaceBody.Edges.Count}")
        for k in range(1, surfaceBody.Edges.Count + 1):
            print(f"      Edge {k}")
# Execute the function
AssemblyJoint()
YuhanZhang
Try below updated code to check if the result is as expected:
    if not face1:
    if not face2:
    if not edge1:
    if not edge3:
    #edge1Intent = asmDef.CreateGeometryIntent(edge1, 1)
    intentOne = asmDef.CreateGeometryIntent(face2, 57867)
    intentTwo = asmDef.CreateGeometryIntent(face1, edge3.StopVertex.Point)
    # print("Edge1 Intent:", edge1Intent)
    try:
        return
            print(f"      Face {j}")
            print(f"      Edge {k}")
AssemblyJoint()
You used a cylindrical Face to create a GeometryIntent, that you can below Intent values (from PointIntentEnum) to specify which point on the cylindrical axis will be used:
kAxisEndPointIntent 57867
kAxisMidPointIntent 57866
kAxisStartPointIntent 57865
Rocky
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Thank You
