Inventor API Material Reading Issue
Message 1 of 8
I have attached Inventor 2019 assembly.
Please refer the assembly “Fishing Rod Assembly.iam”.
Loading the part file "Fishing Rod.ipt" gives different face colours. But when we load the top-level assembly (_Fishing Rod Assembly.iam) it gives the same color for(Fishing Rod.ipt) all the faces.
Replies (7)
Message 2 of 8
HideoYamada
I downloaded attached file and got same colored views about "_Fishing Rod Assembly.iam", "Rod Assembly.iam" and "Fishing Rod.ipt".
(I tested it with Inventor 2019 Japanese)
If you have changed the color in the top assembly, you can do "clear" overridden colors.
See the video.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 8
HideoYamada
If you can't see the video in the last post, click the link follows.
https://autode.sk/2zD1Tek
Freeradical
 Hideo Yamada
Message 4 of 8
Hi
I used to call "ClearAppearanceOverrides()" function to clear the overridden colors on top assembly, parts and bodies. But still, we get the override color.
Eg:-
#pragma implementation_key(1090)
inline HRESULT AssemblyComponentDefinition::ClearAppearanceOverrides ( const VARIANT & AppearanceOverrideObjects ) {
return _com_dispatch_raw_method(this, 0x600022b, DISPATCH_METHOD, VT_EMPTY, NULL,
L"\x080c", &AppearanceOverrideObjects);
Message 5 of 8
Darkforce_the_ilogic_guy
inventor for some reason do not update new colour before change form one view to a other in representations.
remember also that your iam files need to chosse the same representations - views at the part in the assambly  that you are making the change colour on
Message 6 of 8
HideoYamada
I just run this code and color override is cleared.
ThisApplication.ActiveDocument.ComponentDefinition.ClearAppearanceOverrides
It seems that you are using C++, but try copy above code, paste immediate window in VBA, and run.
Overridden color will be restored.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 7 of 8
I'm running with Inventor 2020. But when I execute "ClearAppearanceOverrides()" method on top-level assembly It returns "E_NOTIMPL Not implemented". I have added a sample code that I have used to call that function.
CComPtr<ApprenticeServerDocument> m_pApprenticeServerDocument;
CComPtr<ComponentDefinition> pCompDef;
hr = m_pApprenticeServerDocument->get_ComponentDefinition(&pCompDef);
if (pCompDef->GetType() == kAssemblyComponentDefinitionObject)
CComPtr<AssemblyComponentDefinition> assemblyDef;
HRESULT hrOfQuery= pCompDef->QueryInterface(DIID_AssemblyComponentDefinition, reinterpret_cast<void**>(&assemblyDef));
if (SUCCEEDED(hrOfQuery))
     auto retVal = assemblyDef->ClearAppearanceOverrides();//Returns E_NOTIMPL Not implemented.
Message 8 of 8
HideoYamada
Sorry I've never coded for Inventor in C++, so I can't help you anymore.
Have you already tried to change the view representation of sub assembly or part to "Default" and set Associative?
This will cause reset face colors also.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
